big 16g question
csprakyfly
Oct 12, 2002
Las Vegas, Nevada
I Was wonderign what types of power gains are gained off of clipping the wheel 10deg on a big 16G. What should I be getting full boost at? Thanks for the help!
I think clipping the wheel helps more on top end than anything else. Not quite sure if it helps spool though.
once again, clipping helps on top end, but it induces more lag. If you are that crazy about top end just get a bigger turbo and port it so spool up will increase.
