BryanK
- 131
- Jun 25, 2002
Iowa
Welp, I'm showing some of the early signs of crankwalk. I lose clutch pressure on left turns (sometimes just regular driving, but too often on left turns). Its a '95 gsx w/ about 100K on it... I did some research on it, and this is what I'm wondering. First, so what if I have crankwalk? The engine is trashed now anyways, no use in rebuilding it since crankwalk returns on like 99% of all crankwalk cases, so whats the harm in driving the car as is? Worst case scenario I bust my crank positioning sensor... will that mess up my entire car? Will I screw up my tranny beyond what a new ACT 2,600 will fix? Should I just go ahead and drive it with the crankwalk until its too bad to drive anymore? As I lose more and more clutch pressure, I'm wondering what the proper procedure is for "clutchless shifting". Not sure of the exact terminology for it... but the shifting when, to my understanding anyways, you just slip it out of gear (any special way of doing this?) and then match driveline rpm's with engine rpm's and shift it into the next gear right? How exactly do I match rpm's? I just don't want to prematurely screw up my tranny.
Now to the fun stuff. When I do get a new engine, what should I do. I was just going to go for a buschur 6 bolt shortblock buildup, but are they even worth it? Should I just get a 6 bolt with some nice components and have a local shop do the building?
I was also considering a 3000gt V6 engine... I figure a buschur stage 3 would be like 3K, so for that $$ I could prolly swap in a 3000gt TT 6 cylinder right? Has this ever been done? What would be the benefits of doing this, if any?
Thanks for your time,
Bryan
Bryan
