pickens
- 544
- 5
- Jan 17, 2003
Southern California,
California
I believe I read that the stock dsm turbo injectors are rated at 450 cc/min at a standard fuel pressure of 43.5psi. Now if it is true that the stock injectors flow that much fuel at that fuel pressure, then they are really flowing more fuel in reality. Most dsms run a base fuel pressure of 41-43psi (vacumm hose disconnected). As the boost rises, the fuel pressure also rises linearly. Therefore at say 15psi, the fuel pressure is around 56-58psi. At that fuel pressure, the stock injectors should be able to flow around a calculated 525cc/min. If you bump up the base few pressure a few psi w/ an adjustable fuel regulator, then you get a flow rate of 550cc/min which is good for around 325HP at the crank. So, why is everyone so quick to say they need larger injectors to run relatively small in size 16g turbos. Please discuss.
