top end
jerzeytib
47
Dec 6, 2003
East Oragne, New Jersey
What up? I have a question........In order to make my 90 gs-t a more top end kind of car what kinds of mods do I need to install. To help you guys out I'll be getting the 20g along with everything else i'll need to support the upgrade.
cams will help out the top end. 264's are pretty good. 272's will improve top end even more. also, an intake manifold will help too, shorter runners = more top end. magnus makes a good one, there are others, but i don't know much about them. hope this helped.
peace
Work on the head. Ported (This is up to you. First gen heads flow alot of air already), upgrade the springs and retainers, 272's (which was mentioned above), Extrude Honed intake manifold, and a bigger throttle body. The block is fine, but you want to make sure there is enough room to take the RPM's above 7500. The higher the RPM, the better. Oh and a GVR4 fith gear will help (its higher).
You don't really need port work, or a different top gear, or a new throttle body. Start out with the basics, cams, a good flowing exhaust, a good flowing turbine side, and a good FMIC. Then you can decide if you need more.
