mwreed
- 84
- May 5, 2003
Phoenix,
Arizona
I hope this is in the right forum.
Sorry for the long post, but, I think this is pretty cool. I hope you find it useful
I needed a boost controller and since I am a tight wad, I decided to use the plans for the DIY MBC. It seemed simple enough and was logical to me in functionality. At any rate. I also wanted to be able to switch between boost settings as well. I was looking at the dual stage boost controllers and doing some research and found that to switch between stock and high (or whatever you want) you just need to be able to make the flow go from the source straight into the wastegate actuator and your MBC to set the resistance of air flow. After looking around and doing searches here and on the web, I found a design that gave me an idea. I don't remember the link, but, I think it was the poor mans profec. Not sure. If I can find it again, I will link it. So then my quest led me to looking for an air switch. I then realized that, wait, I already got one. The BCS. It will not be used with installation of the MBC, so, why not use it. So, after a little planning, I figured out a way of utilizing the BCS to create a dual stage MBC. The important thing to realize is that the BCS is closed when there is no power to it. We want it to be open by default and closed when we want boost. I figured that I would use the standard automotive relay, you know the one used in audio installations? The idea is that you supply power by default and the move the switch to turn off the power to the BCS. Really, that is a simple task, but, I like lights.
I got a lighted switch. So, I wanted the switch to light up when I had high boost and off, when I am at stock boost. Hence the need for the relay. My original plan was the hook the relay up where, when you flip the switch to turn on the relay, it would open the circuit to the BCS and turn on the light on the switch. Pretty easy, really. To my suprise, the switch I used made this possible without the relay. The switch the I used supplies power to the ACC when it is off and turns off the power when the swich is on. I guess you can hook it up different ways, but, I found that this option worked great for me. Another very important thing to realize is that you need to make sure that your power source is only available when the car is on. Fortunately, I have a turbo timer and could tap right into the ignition lines right near the switch. I mounted the switch in the coin holder. Will supply pics later. Let me know if you have any questions and I can explain more. I just thought this was a good way to control boost in a relatively inexpensive way. I will tell that it does work. I was testing it last night and flipped the switch. It jumped to 20psi... not good on my small 16g. I then experience fuel cut, however, I was watching my boost gauge and flipped it back as soon as I saw it hit 20. I am still adjusting the setting on the MBC. The point was, that, because of the swich, I was able to immediately open the wastegate and reduce my boost and did not have the complete experience of fuel cut. Nice safety device.
Michael
I found the links I used.
MBC - http://www.geocities.com/chmwatson/FAQs/mbc.html
Dual stage setup
1 - http://pages.cthome.net/gus/pictures.html - helpful
2 - http://www.xmission.com/~dempsey/perform/recipe_b.htm - this one was the best help.
Michael
Dual stage setup
