stock1g4g63
- 1,193
- 1
- Jan 2, 2003
(was TX) Anaheim, CA,
California
Ok guys, before you tell me, yes I have done extensive research on crankwalked motors and have looked at many the possible solutions. Including the 6-bolt swap, the 2.4L hybrid, and some of the smaller fixes. My question is more of a survey I guess, but how many people have started to experience symptoms of crankwalk, and then built/rebuilt their motors (obviously replacing the crankshaft and bearings) eliminating symptoms? If so, how'd it work out? And what was done/changed?
The reason I ask is because I think I may have had some symptoms of crankwalk (ticking sounds, sticky clutch) at which point I changed out the thrust bearings and have been going good for about 8k miles. I plan on building my motor, or just swapping out to a 6-bolt alltogether. Of course, either way, I will build the motor that the car will run on. I also debated the 2.4L hybrid, but don't know if the cost is worth the power gains/spool up time. All opinions and suggestions are welcome. Thanks in advance.
