BlackMage
- 34
- Oct 3, 2003
Oakwood,
Georgia
you guys thing this would help along with ceramic coating the manifold in controlling enguine bay temps and keeping heat inside the exhuast system?
and only noticed because I could see carbon building up on my water pipe that runs across the front of the motor.
.Originally posted by BlackMage
Originally posted by 98TsiAWD
If you use jet-hot 2000, yes it will lower your underhood temps.
Check out their website, www.jet-hot.com
The 2000 coating is good for 2400 degrees, and it can cut heat in half on the surface of your exhaust manifold, turbine housing etc.
My spf manifold, exhaust housing, 02 housing, and dump tube are going to them next week sometime hopefully.
Originally posted by Strm Trpr
What's up fellas?
Has anyone sent their parts to SBR for porting?
They have a pretty killer deal, they'll do your exhaust manifold runners full length, port your turbine housing, install a 34mm flapper and port your O2 housing for like $230 bones with ups paid return shipping?
Peace
Originally posted by Groomz
And this has to do with ceramic coating how? I smell a shameless plug....
In terms of coating the turbine housing, does the coating interefere with the turbine blade to housing clearance at all?
-Groomz
