hellotbone
- 1,032
- 22
- Apr 15, 2003
As the topic states should my boost be set to sustain 16PSI with my stock turbo at WOT or at the spike meaning if I stab the throttle I hit 16 PSI then fall to about 14PSI should I up the boost to hold 16 PSI which would puch the spike higher.
Also what would cause a boost surge under steady throttle at about 1/2 or 3/4 throttle my boost gauge when the motor starts to take on a load hill or something it will bounce the boost gauge about a psi give or take what could cause that?
