kr.k
- 215
- Aug 9, 2002
I am on about 4K miles after a rebuild and I am getting 10-11-11-10 bar compression on my engine from right to left. Is that low or in spec? I have 8.5 pistons in there.
Originally posted by Mike 99GSX
I'd say thats a little low. Stock 2g compression is supposed to be 178 PSI and your looking at between 147-161. Everything should be plenty seated by now. Are you sure all your timing marks are right?
Originally posted by ecr1055
what type of head gasket did you use? If u used a thicker or metal head gasket, that could of lowered your compression.
