Is Thermal 3" A True 3"?
nolv4v8
104
Oct 21, 2002
Milwaukee, Wisconsin
Is a Thermal cat back exhaust a TRUE 3" exhaust and are there any resonators? Currently I have a Apexi Dunk 3", but it seems to neck down and it has the resonator. Will I see a difference between the two at around a 400hp level?
Well, a Thermal is a true 3" exhaust after cutting the section that necks down. After that, wedling a 3" peice with the same size flange shouldn't be an issue. Other than that, you can't get better than that without for a mass produced exhaust.
I have a full 3'' from the turbo back I weld a new flange on the reducer part to get a real 3''.
Had a 3" thermal on mine and it was true 3. it was 2.5 at the DP flange in order to mate witht the O2 housing.
I also cut off the neck down at the stock cat. Other than neckdown, it is a true 3". No resonators either. I have seen several other exhausts and the thermal seems to be the straightest flowing and least restrictive of any other exhausts I have seen.
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
