BUCK
- 2,442
- 19
- Dec 11, 2002
Summerville,
South Carolina
I'm seeing what looks like 13psi Boost on my stock boost gauge. It will hold right on the 1 in the 14 when cruising at real high speeds & when ran thru the gears at 5500 - 6000 rpm or so. Needless to say it runs GREAT & purrs at 800 rpm in idle.
This is a change since I replaced a bent #1 rod & put in all new 1G pistons (it was pulling about 11psi before that repair - still ran very good).
My only Mods are:
- balance shaft delete kit
- a gutted Cat
- No evap canister & associated purge lines.
- no EGR & associated lines.
- no vacuum lines going directly into the top of the Throttle body (all capped of course.
- Turbo vac lines are stock.
PCV & Valve cover vent stock.
Base timing set very conservatively - probably 4 BTDC (spec is 5)
Runs at 7 BTDC when Timing connector is not grounded (spec is 8)
using 93 Octane here in S.C.
I have no AFC, etc... but it may be time...
The $3000 question is will this 13psi cook something? Knock sensor is brand new - I THINK I saw some fuel cut in third gear at 5000 rpm when I floored it all the way & quickly rapped it out hard to 6500 in first & second. It just hovered at 5000 rpm.
I hated to put this in the Tuner Forum being I'm not running any AFC.
Thanx in advance for any advice, Buck
My only Mods are:
- a gutted Cat
, so the stock gauge is totally inaccurate, don't go by that at all.
