Hrc 20g
madracer247@aol
243
Aug 5, 2002
la, California
My friend wants to sell his brand new 20g his going to give it to me for 600 what do you guys think i get everything turbo manifoldm and o2 sendor housing ok well let me know guys
Super 20G-N-fits 95-99 Talon/Eclipse w/ High Flow Manifold: uses H TU-4235 install kit, and H TZ-1605 O2 Housing, supports 500HP w/no boost creep, 15 PSI actuator, no external wastegate required. H TU-2125 Was $849.00 Now on sale! $799.00 More
Heres a link to what he has ....
http://www.hahnracecraft.com/hahn/parts/s20gn.htm
yea about the turbo does anybody know that turbo what is the lag like. I really havent heard any thing about this turbo. what do you think about it....
i asked a similar questions before. some people love the turbo and some people hate it. im yet to install the hrc turbo because im still waiting for the install kit/ o2 housing. most of the people that OWN the turbo says lag is not that bad, around 3800 rpm (full boost).
ok well cool guys so you think this a goo deal on everything.Looking at it from every point of view ex. price, quality and etc .....
I had that turbo and it was an excellent turbo! spool was good and the power was SICK for a 20g, killer mid o top end power. you are going to need 660cc injectors with it though if you want to run a good amount of boost on it. i ran 21lbs w/ 550's and ran really lean, finally switching to 660's. a LOT has changed since then.
point is.......... buy it ( make sure there is no shaft play) its a nice turbo. you'll like it
JP
back when I bought min I didnt get the n it spools about 300 rpms slower than the others, then the "n" stood for the nitrous version. being more nitrous friendly and handling it better. I love the turbo, on a stock block 2g I was at 10-13 lbs right around 3300rpms. they do creap to around 18 lbs on the 15lb acctuator. I was running 550s as well, worked out good. good luck
can someone please explain to me why this turbo would not need an external wastegate to not get boost creep?
Great turbo for the price. A little laggy but the mid and top end more than make up for it. Ran mine at 19lbs low boost and 24lbs high boost. After tuning with my Apexi S-AFC, and the Warblo 225 pump and rewire done turbo went from 3700-3800 rpm to boost to 3200 to 3300 rpm. Turbo boost all the way to redline and beyond (if your engine can take it)
even in 5th. I ran out of gear even in 5th and my turbo was still pulling hard.
