96TalonTS-jets8
- 45
- Oct 30, 2003
I got a 96 Talon TSI (FWD) and it crankwalked, so now I have to replace motor. Right now I just got everything unhooked, from the top of the engine compartment and the axles. The only thing holding the motor and tranny is the 4 mounts. My question is which way is better to get this engine out? because i have another engine waiting to be attached to my tranny and then dropped in. I have a engine crane, but i can only lift car about a foot and a half off the ground. Should I drop the tranny then pull motor or pull both at the same time. When I was looking at just droppin the tranny 3 out of the 4 mounts hold it in place. So any help would be appreciated. Thanks.
). But yes, good luck, it isn't hard, but do label everything before you unhook everything.. You might think you can remember where everything goes.. But after the engine is out, and you look at the mess left.. you quietly think to yourself... "oh man.. there sure are an awful lot more wires then I remember seeing with the engine in.)
