Resolved What is the thread size on the head for the oil feed line?
1992TalonTsi
Oct 2, 2002
I am looking for an adapter so i can install my braided oil feed line onto the head cuz i cant get out the bolt on the oil filter housing cuz at 114K miles i thinks its kinda hard without having a good blowtoucrh. Can someone please post what kinda size adapter goes in there so i can fix my car.
so i gotta find a threader that wil make it 10mm x 1.25 on my new oil feed line so i dont have to buy any adapters. thx
If you can't find anything to retread the braided oil feed line you are going to need a banjo bolt that goes from the head into the braided line. you should have a standard size braided line, check out this link....
http://www.pingelonline.com/brake_accessorie.htm#BRAKE LINE2
......they have plenty of fittings that will work. look in the middle of the page under zinc plated brake adapters, then look for letter "A", that is more then likely the fitting you want. You can always bring the line to a local auto parts store and have them determine the size and pitch of the tread you will need. Hope this helps.
yea looks like i will order the 180 Banjo Fitting. I am using the standard fitting on the braided line so i shouldnt have too much trouble with that then i guess. Thanks allot
