Turbo Timer Question
jbchase
Aug 9, 2003
How well do turbo timers work with aftermarket alarms. If the car will remain running with the key out do I need to engineer a curcuit to active the alarm after the car has shut off?
Also is the Greddy turbo timer harness different for Automatics and manuals, I have an automatic that is being converted to a manual next spring, but want to use the turbo timer now.....
Thanks
as far as i know you dont need different harnesses. The ignition wires shouldn't be different. I dont know why they would be but you never know. In Fact i really really doubt that they are different. In manaul gsx it was a snap. I would suggest having a test light if you end up not using the harness.
I have a viper alarm with a greddy turbo timer. The alarm works with the TT, but it wont arm itself after it has shut off. Theres a way to make it work....i just dunno what it is.
