engine swap
dman_ss
Nov 2, 2003
newport, Michigan
can anyone out there help? i have a 2 gen turbo talon 96, want to do a 1 g swap what do i need to have? i have a complete 6 bolt block ready to go in . wiring harness differences? motor mounts? please help thanks
There are several things that you will need, going to magnusmotorsports.com is a good start, but if you want to se the finished product, you can come check out mine and I will explain all the difficulties you will encounter. it's not to bad if you have a used motor with everything still on it but if your starting with a bare longblock be prepared to buy a few things:D
hey thanks for the quick reply, i do have a complete motor ready to go so where you located? im downriver area if its easier you can just email me at [email protected] thanks again Dan
This months issue of modified magazine has an artical about a 6bolt into a 2g, not a very good artical, but it is something.
