2G 6 bolt swap oil cooler ?
custom240sx
91
Sep 9, 2002
I want to keep my 95 oil cooler, is there any way i can do this? I am swapping in a 6 bolt and i need to know how i can do this. Also when i bought my oil pump, it did not come with the oil filter adapter, can i use the one from the 95. And if use my 95 parts what water pipe do i need? Will i need the nipple or not? Thanks for the input.
can you use the 95 oil filter housing? with the oil cooler? if not. which housing should be used?
the oil cooler i picked up should be for a 6 bolt i am not sure if it is the right one, it is about 10" x 8" x 1.5" (that is a guess) And it has 2 lines coming off of it for banjo bolts. What year is the from? Because i need to know what year oil filter housing to get, thanks for info too.
So what you are trying to say is that you have a air cooled oil cooler, That was used in 90 and you need a 90 oil filter houseing to use that one of the venders on this site sells them for both 6 and 7 bolt blocks.now if you have a 6 bolt you have to use the one for the 6 bolt the bolt holes are diffrent.. :talon:
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
