simpe ? about compression
2G's have higher compression than 1G's. 175 is fine for a 2G. Not sure how low you can go before rebuild so I dont know how bad you 160-165 is. Maybe a 2G guy can help.
ok 1g stock compression 7.8:1 gets 165 compression brand new, the 2g with its 8.5:1 gets 180 compression brand new. service limits is the same on both engines, i believe they state if the compression is within 15 points of each other that is fine as long as its above 120. now on the service limit thing i am 90% sure, but the comp. values i am 100% sure. hope this helps
Bryan
