Corman12345
- 117
- Jun 22, 2003
Laramie,
Wyoming
Here it is. I just replaced my valve stem seals and when I had the compressed air hooked up to all of the cylinders to keep the valves from falling in the cylinder, i kept hearing the oil in the motor churning and splashing loudly. I then did a compresssion test and all four are running at 152 psi. the only thing i could think of is a blown head gasket and the air leaking into the oil, but i just replaced that about 6 months ago and the compression tests kind of ruled that out. I was just wondering why this would be and if i should be worried about it
thanx
thanx
