Greddy Boost Gauge electrical issues
Mistaspakles
227
May 17, 2002
Just a quick question. Can you guys let me know what your Greddy Boost Gauge is registering when the car is shut off? Mine is at 0 (9:00). I thought it was supposed to be at the 6:00 position. Please let me know. I'm having issues with something in my car slowly draining the battery. Thanks.
You have it wired wrong. If its at 0, that means you probably have the orange wire(keyed 12V) tied directly to the battery. That will leave the gauge always on and drain your battery. Mine is at 0 with key on, then goes to the bottom of the scale with the key shut off.
Here are the directions to wire it properly(and also to make it work with the stock dimmer on a 2G)
