Greddy Emanage or DSMlink
powerdbydsm
62
Sep 20, 2003
Portland,
what do you think its better for tuning??? Greddy Emange or DSMlink. or is there something you would recomend other then these for a reasonable price.
Had the same question. Searched on this site. Answer? DSMlink. Everyone that switched from something else to the DSMlink has loved it and its abilities. It should be the first thing you buy for tuning, and it will be the last.
any one else agree with im on this??? Caue I have a emanage now and I have some that wants to buy it, if I sell it I would need to buy something else really fast, and if the DSMlink is better and worth switching too then I will do it.
does the DSMlink let you controll ignition timing?
I have setup and tuned a sr20det with a E-manage. Its not a bad system really. The only thing I really didnt like was the datta-logging part. The few things you can log are point less really. But With little tuning the car went 13.3 at 106 on street tire's, with a 60ft of 2.2 on pump gas. All the car has is full exhaust, intake, 255 pump, boost controler set to 13pd's, front mount and hard pipes. Before the emanage, we were using a HKS AFR. We could only hit 13.8's at 100
Yes, but DSMLink has much much more DSM ECU specific toys that make it that much better.
DSMlink , can you controll ignition timing? and the emanage is way way way beter then a SAFC.
DSMlink , can you controll ignition timing? and the emanage is way way way beter then a SAFC. Shesh, maybe I will just save and get a full stand alone :|
DSMLink can control Timing/Fuel/everything that you could ever want. How about you just go to DSMLink.com and go look around.
So you are saying you searched the site and found the OTHER thread titled "Greddy Emanage or DSMLink?" I found it pretty easy when I searched too. Someone should probably post the link to it, since poweredbydsm couldnt find it when he searched.
http://dsmtuners.com/forums/showthread.php?s=&threadid=51896
Brad
