SportinWood
- 108
- Feb 9, 2003
Bellingham,
Washington
People who have these please tell me the limit of the GM and if it's really worth it compaired to the Apexi SAFC..... Pro's/Con's ect.
THANKS!
THANKS!
Originally posted by Wobble
SAFC wins hands down, the MAFT flows more air.. but untill youve got a SUPER huge turbo that isnt gonna be a factor.. the SAFC lets you tune from in-car, have finer tuning, playback and all that good stuff..
with the maft you have to get out.. take off the cover, turn a screw or 2.. get back in.. try again.. etc etc..
and a MAFT is about 300 for the maft and the translator so price is similar between the 2...
but my money is on the SAFC.. its just better all around as far as tuning goes..
Originally posted by newports01
the gm maf and translator will also allow you to disable fuel cut right?
Originally posted by allwheelTSI
no.
Originally posted by 98eclipseRS
why do you say NO. It has the function to disable fuel cut.
well.. unless they came out with a new version like yesterday.. i know that is incorrect. the only piece you can set injector size on is a DSMlink.
and if you don't know for sure about the fuel cut thing,i do.
i think you misunderstood something. you get fuel cut when the computer senses too much air,it reads air in 'hz' what the MAFT does is allows you to lower this signal to compensate for bigger injectors and to help not to hit fuel cut,it does not eliminate it,because fuel cut is a function of the ECU and the MAFT dose'nt alter the ECU,only what the ECU reads.
Originally posted by nine5raptor
It is a percentage adjustment. The manual comes with settings that are close to what you would want for a given injector (with the top one being like 1250 cc/min if you have an extreme setup).
obviously you have never seen anyone mount the translator box in the car. nOt only that but with the reduced restriction that the gm mas has it reduces turbo lag regardless if you have it in a draw through or blow through. Price is a ilttle much but use the trader I just bought a translator new gm maf(from the dealer) and dejon tool blowthrough uicp(also brand new) for 400 shipped 2day from across the us. I am in no way knocking the safc it is a great tunning tool and it will be the next thing I buy but the translator is more than worth the money IMO. Is is also easier to get your idle under control when using largert injectors with the maf/t. And as said above you can vent to the atmosphere which means you can run a higher quality bov without any side effects.
My friend has the GM maf, and no you cant vent to the atmosphere with it UNLESS you get the blowthrough setup which requires quite a bit more cost..
and reduce lag? maby if you have a GIANT turbo where the stock maf is a restriction.. otherwise.. no difference..
higher quality BOV? a Greddy Type S or Type R isnt high quality enough? even HKS makes a recirculatable BOV.. HKS is cheap?
as for idle, well my friend never got a good idle with it with 550s, but it turned out one of the injectors had a little leak so maby that was it..
but the bottom line is the maft tunes in increments of 5% where as the AFC tunes in 1% and averages between too.. if you set 5000rpm at -16% and 6000 at -15% then 550 is -15.5%
as for mounting the maf box in the car, no ive never seen that done.. though i suppose you could.. you can also put a MBC in your car by running vac lines all the way inside.. yay
