GT40MkI
- 40
- Jul 8, 2003
After a month of hunting around for an oil feed/water blockoff kit for my SCM61 from PTE, the damn thing is bolted up, water has been blocked off, and return line has been connected. My question comes with an oil feed source.
I have 2 friends who are very DSM educated, with conflicting advice.
One says the hex plug is the best source, as its high pressure and freshly filtered, and seems to be the safest for the turbo.
-HOWEVER-
One says that the pressure coming from that plug is too extreme for the turbo's seals and will blow them out. He suggests a feed off the cyl head right by the OEM feed.
Should I put a filter on the cyl head feed, or is there a way to regulate the feed by the filter?
LMK asap , I'd like to do it tomorrow...
-Sean
-HOWEVER-
-Sean
