Turbo Selection
4g63spyder
Jul 2, 2002
OK, Right now im thinking of either going with the fully modded tre big 16g or a t-28. Im really not sure what to get cause the only turbo ive felt is my t-25. I want a turbo that will last and put me in the low 13's but be very streetable. What do you guys think about these turbo's or is there something better. Also what other mods should I get besides the ones I have. What size/brand injectors, what brand fuel pump? Thanks
both the big 16g and the T28 will get you in the 13s
you might wanna check out some 550 inj and Walbro 255lph fuel pump, and a AFC to tune that baby w/, if that doesnt get you in teh 13s then look into gettin a front mount intercooler.
good luck, let us know what you decide on.
yep, the 16g you have to spend 200 for an installation kit and its more of a hassle to install. Get the FP Big28 from www.forcedperformance.com Its pretty equal to the 16g and is a direct bolt up, less hassle.
Big 2 is less hassle and would be the better choice between those 2 turbos.
YEAH, I was looking on FP's web site at the big 28 and was going to ask you guys what you thought. It looks like a really good deal. How does it compare to the big 16g in power? Should I use 550?s with the big 28?
Well i would think with that fwd and street tires, you would need good tuning and good supporting mods to run consistant low 13's as traction will be limited. It seems that the bigt28 is getting very popular, and it measures up very well against the big16g. It seems like a great upgrade for your goals
    • eclipsemf
