Enigma_Man
- 936
- May 15, 2002
Lawrence,
Massachusetts
In reading and thinking about turbos, I had this idea:
Everybody talks about bigger turbos having more lag, and requiring more supporting mods, etc.
What about putting a big turbo on a basically stock car, but just keeping the boost down. I know that there would be more air going into the engine, due to cooler temperatures, due to slower spinning turbo. But wouldn't the lag time be not noticeably more, when running at approximately the same psi as on a smaller one?
Also, PSI is PSI, reguardless of turbo, the only thing that changes is intake temperature. I know that a larger turbo can flow more, but that only comes into play when the engine is sucking more air than the turbo can deliver, which would then make the PSI drop off because the turbo just can't supply enough air to maintain the pressure, which doesn't seem to happen on a good sized turbo.
I have a 16G on my car, and no fuel mods (I'm poor, I want them, I just can't afford the ones I want), and I just keep the pressure at 11 psi. I have no difference in lag (though my 14b was toasted, and the 16g isn't that much bigger really).
What about if I took something like the AGP L2R, and just ran that at 10 psi, assuming everything could keep up with the cooler air and whatnot. It would take very little time to build 10 psi on that turbo, I would think. This would help eliminate the buy-twice thing for some people. I dunno, I'm just curious about it, and super-bored at work.
-Jesse
-Jesse
