IPT
- 1,092
- 4
- Mar 31, 2002
Des Moines,
Iowa
OK. Some time for ideas.
I am tuning my 1G. Using the PMS datalogging and I can not get the car to award timing above 6000 rpms
I data logged my car a couple of months ago with a Pocketlogger and I had the same problem. I thought I had a problem some where else and did not think of it. It as the same thing. On the posket logger I could get it to 0 counts of knock and then at 6000 rpms the knock count would spike and the ECU would pull timing.
The same thing is happening now. I get a good timing curve (up to 25 degrees) before 6000 rpms. As soon as I get to that point the timing starts getting yanked!!!
I have tried to richen the mixture up to help, but I keep richening it up til the car will sputter. I started off on the lean side and worked my way up to the sputtering. My O2 voltage is around .92 up until the 6000 rpm mark and then I drops to .88V
This is starting to piss me off the car pulls GREAT until 6000 rpms and then it just falls on its face. I will be replacing the O2 sensor here and try that. I will also be checking to see if the knock sensor is "looks" bad. (the epoxy is starting to some out) Other than that I am lost.
HELP!!!!
Any ideas?????
I data logged my car a couple of months ago with a Pocketlogger and I had the same problem. I thought I had a problem some where else and did not think of it. It as the same thing. On the posket logger I could get it to 0 counts of knock and then at 6000 rpms the knock count would spike and the ECU would pull timing.The same thing is happening now. I get a good timing curve (up to 25 degrees) before 6000 rpms. As soon as I get to that point the timing starts getting yanked!!!
I have tried to richen the mixture up to help, but I keep richening it up til the car will sputter. I started off on the lean side and worked my way up to the sputtering. My O2 voltage is around .92 up until the 6000 rpm mark and then I drops to .88VThis is starting to piss me off the car pulls GREAT until 6000 rpms and then it just falls on its face. I will be replacing the O2 sensor here and try that. I will also be checking to see if the knock sensor is "looks" bad. (the epoxy is starting to some out) Other than that I am lost.
HELP!!!!
Any ideas?????
