Big 16g boost creep
bizzydsm
57
Feb 27, 2003
Mountain Home,
I have a full 3in exaust with a 3in o2 housing! I bought it through nate at dsmotors. I asked him how to stop or slow boost creep and he told me to port were the waste gate actuater vents into the o2 housing....he said port the crap out of it, just make sure you dont break the seal on the flapper! my question is what is the best tool to use to port it, and do you think it well help.
Thanks
_Ryan
Originally posted by DSMSpyder99
personally i would pay to get it ported cause i have a tendency to screw up. but if u don it urself a dremel should work
I have my old cracked 14b, Ill problebly practice on it! Ya a dremel with a diamond grind stone should work good
Thanks for your reply!
_RYAN:thumb:
Uhhh, a dremel will take about 2.345 million days to do that on cast iron. Do yourself a huge favor a get a pneumatic powered die grinder with a carbide bur made for cast iron (not aluminum). Should take about 15-20 minutes as opposed to 2.345 million days.... ;) A dremel just does't have the poop for porting iron unless of course you have the patience of a sloth.
What do you have your boost set at? A Big16G with stock flapper shouldn't be creeping unless you have your boost setting pretty low or your wastegate acutator is worn.
Mike
Mike
sorry I have not been on the web the last day or so. I had my boost set around 15 pounds. It doesnt have time to creep in 1st, it starts to creep at the top of the rpm band in 2nd and 3rd. Is there anything besides porting for boost creep?
:) thanks
_Ryan
:) thanks
_Ryan
Mine was creeping at anything less than 15psi. I'd say bump it up to 15, if that doesn't hold, bump it to 16 and log it. Make sure you're not getting knock etc..
What kind of a MBC are you using?
Mike
Mike
Im using a dialmond star specialties MBC.
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
