Brian
- 154
- Mar 26, 2002
toledo,
Ohio
Alright I just got done finally doing the 6Bolt swap in my car and was pretty confident. Well it isnt starting now, let me explain. At first it was not starting at all like when I turned the key all that would happen is the lights would get dim and it seemed like a power issue so I hooked it up to another car and still the same thing. So my friend goes down to manually turn the crank a little, maybe give it a bit of help since it hasnt been started in awhile and then it does try to start till I hear this loud metal on metal knock and it does that once and the car stops trying to start, so we manually turned the crank as much as we could and it doesnt go very far maybe 1 1/2 full rotations with the socket then it stops and doesnt allow us to turn it any farther, so we try to start it and it does the same thing over and over, it will try and start until that click, like something is getting caught or stuck on something else. I think it sounds like it is coming from the crank pulley side of the engine somewhere, but the flywheel or clutch side is a possiblity also. I have gotten a few suggestions saying that it could be a piston hitting a valve, but timing seems to be good. I was suggested to test the compression which im going to do today also. One thing that we were stupid about and forgot was to pull the spark plugs when cranking it which may be why we couldnt turn it very far till it would stop, so I will pull those today and crank it and see what it does then. Even if it does crank like normal, would not having the plugs out cause that noise, the noise is what is scaring me. Give me any suggestions or tips and that would be great, I've gotten this far I would like to try and keep it out of a shop.
