Timing cover gasket question.
DSMRevolution
1,629
11
Dec 6, 2002
Sioux Falls, South Dakota
Insted of purchasing a new timing belt cover gasket, could I use some Ultra Grey sealant in its place? I want to keep moisture away from my timing belt, and this seems like the best, most confined way. Has anybody tried this before?
The timing belt area is supposed to be ventilated. That's why the crank pulley has fins cast on it's backside; to pull excess heat out. Just make sure you have the stock plastic splash sheild in place between the engine bay and the drivers side wheel. That will keep the belts clean and dry.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
