Why hook up mbc to bov return instead of turbo?
truwarrior
1,422
6
Dec 19, 2002
I'm gonna hook up my mbc and I was gonna hook it up to the turbo like the stocker boost controller but everyone seems to say to hook it up to the bov return line for the boost source. I'm still useing the t25 if that makes a diffence. Also where can I get those little nipple things to cover up the vac port and boost source from the turbo if i hook it up to the bov return line. I never had to use them before. The boost controller came with no vac lines or nipples.
Thanks.
Still not sure where to connect it yet... :(
Vfaq says get the boost source from the BOV Vac line, but I would think the turbo nipple would be a better source...?
Turbo is not a good source for a MBC because it is too unstable. It tends to spike much more, so you never know where your boost is actually set. This is especially noticeable in lower gears.
Tapping it at the manifold gives boost signal a chance to “stabilize” for much more consistent boost control.
That is why most of the good MBCs are tapped at the BOV line.
Leon
RR
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
