Worn clutch pedal linkage :-(
DeathBeast
177
Mar 29, 2002
Bay Area, California
I have this problem:
"1G cars will often suffer from loose or worn linkage. If you can wiggle the pedal with one hand, and you don't feel the clutch master cylinder rod moving with the other hand, you are suffering from this problem. The solution is to replace the pedal assembly, or possibly weld the linkage where it is loose. Either one requires more work to remove and reinstall the pedal assembly, you don't even want to know how much hassle it is. "
-RRE
*Well I do want to know how much of a hassle it is.
-Is it better to weld, or get new parts?
-How long of a job is this?
-Any instructions anywhere on the web?
~Anyone want to fix it for me? :p
Thanx,
DeathBeast
I would like to know this too. I just replaced my somewhat worn 123K clutch with an ACT 2100 along with a new master/slave cylinder. So far all is well and the car feels great.
ok im a bit confused by all the different threads about this, is it the whole in the arms that the pin for the master cyl rod goes through? there is no movement between the pedal itself and that braket, but the clevis with the pin through it is a little loose
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
