greddy profec b with tial 35mm wastegate question
kandt
151
Mar 27, 2002
those that are using a profec b with the tial wastegate, can you tell me were you hooked up the vacuum lines on the boost controller solonoid to. and were did you put the vacuum lines for the wastegate. because my boost controller is acting up. when i start to boost and i hold it at that rpm the boost will keep rising, its not boost creep. because it will rise like 15psi. when i shut off the boost controller i don't have any problems. so i'm guessing its that.
I Take the signal for the head unit from the manifold, but the boost for the solnoid from the LICP. Works like a champ. I still have the jumpers set for an intenal gate too. I cant think of something that might cause the problem you are seeing though. In fact, my problem with the profec is that it will only double WG spring pressure. So on the regular tial 35, your going to have the same max boost as me, about 25-26 psi. :cry:
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
    • 19Eclipse90
  • For sale '90 Laser turbo
    • GregPLT
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
