real stupid question
You get no oil pressure without putting in bearing block offs. The holes for the bearing oilers will just squirt out all the oil and you will not be able to build pressure, not good for your car.
i saw the kit for removing the balance shafts. is it easy to install, or should i wait for a rebuild first and then haveit done while the motor is out of the car? also, i heard somehting about horsepower increase, but i am not sure. thoughts?
Removing the balance shafts is not easy, don't do it if you have not done previous engine work.
You might gain a very small amount of power, but not a ton. It's mostly preventative maintainance.
....Kyle T.
