Remy
- 111
- Sep 4, 2002
bronx,
New York
I am gonna intall my rc 550's and I need a right up I cant see to find one. TIA
Originally posted by 1fast97gsx
insulators rest right below the rail
Like dsmturboawd said the insulators are on the bottom of the injector around the pintle in fitting into the head. The part right below the rail is called a gromit in the service manual or injector sheet in CAPS.Originally posted by 1fast97gsx
insulators rest right below the rail. can )
Yes, you should replace them. Also, for anyone that asked, RC and Denso injectors require the lower insulator. If possible get the replacement o-rings from the dealership being that they are slightly thicker than what most places sell. When installing the injectors, lube the o-rings and the side of the pintles so they slide in easier. MAKE SURE NOT TO GET ANY ON THE TOP OR BOTTOM OF THE INJECTORS WHERE THE FUEL WOULD ENTER AND EXIT UNLESS YOU USED GASOLINE FOR LUBE.Originally posted by Scrymerr
I bought a set of Denso 720s. They did not come with lower insulators. I was told to replace the lower insulators. Comments?
Thanks,
--Dan
