McGruffAWD
- 260
- Sep 10, 2002
I have a friend that just aquired a 6bolt engine. Right now he has a 93 Donor car. I have a 2g and really dont know to much about the 1gs. He wants to know if he can unbolt everything from the firewall on the 6bolt and put it in the 93 and plug everything back in. I told him i didnt think so because they are 2 different engines with diff cam angle sensors and throttle bodys and such. Can he do it? If not what does he need to make the swap work?
Also, what are the factory injectos rated at hp wise? He wants to build the engine to about 500 hp. I know the factory injectors wont go that high but just a rough estimate at what they are capable of.
Last but not least can he run a 255 without a regultor? I know the 2g's cant but if i recall the 1gs reg is alot stronger? Thanks for your guys help.
