2gTurboS
I just installed my greddy oil press gauge,its reads in kg/cm2 which i belive is just the same as bar (i think thats what its called)and after translating my readings to psi my car runs about 7-12 psi at idle and peaks at around 100-110 psi..is this normal ??? just wondering thanks for any info..laters corey...also someone mentioned if i put in some oil additive the really thick stuff that my pressure at idle might stay up a little higher..
