Tank draining question
Mike 99GSX
650
2
Mar 31, 2003
Columbus,
I decided to start a new thread on this to ask my specific question. I made a 4AN hose to take off the return line on my Aeromotive to drain the gas at the track but it took a long time. Someone posted since I have AN lines, I could just take it off the end of the fuel rail before the regulator and it would just come pouring out which made sense to me. The problem is that the car will not start like this without the regulator connected. Did I miss something here or get wrong information? I guess I could keep turning it over because the gas comes out pretty fast but I didn't know how good that would be for the car.
Worse on the starter than any other part, but not good for any of them. Run a jumper switch to the fuel pump.
I really don't like the idea of a "drain" in the engine compartment, either. Despite how irritating it is to have to deal with cold gasoline out in the elements.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
