NJR Racing
- 77
- Aug 8, 2003
i just got my br fmic......how hard is it to install and how much of the bumper do you have to cut.......
Originally posted by peregrine
what does the bumper have to do with foglights?
how much do the passages have to be enlarged and whats the best way to do it.......
Originally posted by KingTSI
its not hard man, unless you did what i did and removed ur front bumper support for weight reduction factor, normally thats what people mount it too...then ud need a welder...i had to make some custom clamps on my VR4 and weld it to the frame...but it works, and its faster thats all that counts!!![]()
Originally posted by DSMJim
I think guys are getting the bumper and re-bar mixed up. THe re-bar is really what the bumper is and I think your thinking the bumper cover which is the painted part on the front of the car is the bumper. Thats just the cover, the re-bar is the bumper.
Regardless, you need to cut the re-bar/bumper to get the intercooler on. Look at the pic of my setup. I just had to cut the bottom out so the intercooler could go up inside. That part where the re-bar is located is covered by the bumper cover anyways so no point in cutting the front out. I had two tabs welded to the front of the intercooler sticking up and drilled holes int he re-bar and put screws through with washers on the inside to get the intercooler mounted exactly where I needed it to be. Then I just moved the vac canister stuff around a little to get the intercooler pipes through with no problems. The other side just hooked up to my existing upper intercooler pipe no problem once my stock intercooler was removed. Lots of room up on that side. (good spot to hide nitrous solenoids etc...)
if so what size bottle is it connected to.Originally posted by DSMJim
I just used clear zip ties and it's connected to a 10lb bottle, yes it's an NX kit. If you get the really skinny but long guys they will fit right through the intercooler core and loop around through again so you can zip em on. My core is 3.5 inches so they needed to be 8" long to make the whole way around and have enough to grab onto. I put it like that so when the bumper is on the solenoid is inside the lower lip on my bumper and you only see the top part of the ring which you can see in my gallery.
You can see it but nobody really knows what it is. Some people ask me what it is but think it's part of the bumper or something like that.
JDMAWD?? what kinda crack am i smoking?? haha go back and read the post...i stated i "removed" the front bumper support for weight savings" the FMIC is now held on by two L brackets inside the front bumper...thats what is "WELDED" Calm down big boy Calm down!!!!
ok lets try this again, ill get specific, the brackets are welded to the FMIC in turn is bolted to the car...better MR.JDM???
where is the best place to mount the coolant overflow bottle......
_____________________________HEY ###, You think your so such a fuking big shot behind your computer, you'll find out who really is in reality...u want me to shut up bi*** u make me shut the #### up, talking shit like this will only get your face broke, and if you think im playin you just let me know and we can meet the fuk up ...ill bet your a 150 lb Zit faced ###et arent you? You wouldnt have the fuking balls to show, or maybe you would...i didnt start this shit you did now either end it, or I will ###et... NOW DECIDE!!!
