96TalonAWD
- 224
- May 3, 2002
Orlando,
Florida
i know they are expensive? thats why i will like to know which should i spen like over 300 bucks on them?
i like the graphivcsOriginally posted by 96TalonAWD
whats wrong with the stock ones? and how do aftermarket cams stay open longer? I mean the cams are rotate it by the sprockets which makes the timing if they are to stay up longer it will be from altering the ECU or the ignition timing?
I dunno i am just a rice boy but BRING IT? jaja
ok i see what you talking about. i saw the little animation from the website jejeje. but i have read that you dont actually get to much HP from cams and you cant get them to big cause clearance?
Once you get an understanding of how an entire engine works, the direction of airflow and the ultimate importance of the air/fuel mixture, you can start thinking of modifying it. The factory gives us this perfectly and if you don't alter it perfectly as well, you won't get very far. If you upgrade cams, you must upgrade everything else to see the maximum performance from them.
