Dan2
- 72
- Oct 6, 2002
California
I have a TMO stage III chip, Big16G w/ 6cm housing, stock IC plus hard upper pipe, 550cc injectors and a GM MAF/K&N/MAF-T with hard intake pipe. The car is a 92 TSI AWD 5 speed w/ ACT 2600. I have a full 3" exhaust w/ no cat.
Before I bought the stage III chip, I would do the usual slipping @ 4500-5000 and the car would generally launch pretty hard (low 1.8 60 foots, sometimes 1.7s).
Launching on the street with the stutterbox, I can't get it to stop bogging. I tried a 5500 RPM launch or two, and no matter how much I slipped the clutch it seemed to bog down. The boost goes to 5-6 PSI at 0 MPH and as soon as I start slipping it, it goes to max boost (15 PSI on pump gas) and the car lunges forward, then bogs down, then goes again.
Anything else I should try? It seems to launch hardest at 4500 RPMs but it's still bogging. Maybe I need to go higher w/ less slipping? Thanks.
