MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
Would anyone be interested in a technical article on low buck coil on plug that works?
I'm getting a set of coils identical to the EVO coils. I'll list the vehicles which these can be found on. They cost me all of $40
Its a double ended system. Example a coil sits on cylinder #1 with a short jumper wire to cylinder two.
Since it was designed for mitsubishi ECU's and engines (off a mitsu) installation ought to be straight forward. I have them on hold at a yard near my friends place. He'll get them for me on his way home from work and drop them off the next morning. I'm just waiting for a day when his shop is'nt so busy that the place is'nt closed by the time he leaves. It's to far out of my way considering I know someone who drives by it daily. The parts guy says it has a connector on it that looks just like a 2g coil connector. It might be a simple plug in operation. If not just wiring the primary wires to the 2g coil harnes ought to do the trick.
