2gTurboS
ok heres the deal,I have a mechanical auto meter oil press gauge with npt tubing (the hard plastic) and tried to install it in place of the factory oil pressure sending unit and the fitting size is wacked so I was wondering if anyone has installed one of these with the greddy oil filter adapter that goes in between the block and the filter and has two spots for gauges one for press and one for temp,any who is this an acurrate location to get these signals,or is there a cheaper way like a factory spot that i dont know about...also does the b&m fuek press gauge and regulator thing have to use that gauge or can you put a sending unit in there for an in cabin gauge..any help is greatly appreciated later corey.
