Hp Numbers Opinions Needed!!!
BOMEX DSM
78
Nov 17, 2002
Chandler, Arizona
Ok me and my friends were just debating on how much HP my car might be making as of right now on pump i say just a little north of 300HP any ideas here? My mods are:
FP GREEN
RRE Downpipe no cat :thumb:
Apex N1 Exhaust
K&N FIPK
Dejon 3inch intake pipe
Walbro 190Lph pump
Denso 660cc injectors
Apex Super AFC II
Greddy FMIC
Tial 38mm External
Running 1.4bar on 91 octane pump gas.
I was also wondering if i drop some C16 whats the max psi i should run with the stock 2G head and stock fasteners. Some HP figures on this would help as well. Thanks for the imput guys all is apprciated(other than smarasses ubcourse)
300+ HP sounds about right with your setup, but a real dyno pull will give you real numbers. I would definately start tuning at a lower boost level than 1.4bar on 91 octane and go up from there if all is well on the datalogger.
I made 330 @~19psi, but only 16 degrees of timing with similiar mods. I also have cam's and a afpr. My Dyno Graph is attached in my Gallery. Like GSX90 said, You might now want to run that much boost on 91 octane. Do you have a way of logging the car? As for boost with c16, unless you have ARP head studs, I wouldn't go past 24-25psi, or the head will start to lift. Good Luck.
