abakja1
- 77
- Oct 28, 2002
Honolulu,
Hawaii
I have a 90 Mitsu GSX,....I did a engine rebuild (broke TBelt) at 120k miles,....Now when I drive my car, all is strong till 3100rpms and above when my car feels "choked off" and has a hard time revving up to its 6500-7000 redline after 3100k,..
I put in 95 pistons, port heads, and minor mods as air can, KN, Dejon 2 1/2 UIC, wires, and MBC set at 15psi,...Right now I have no cat, but a test pipe a local shop did that seems smaller than the factory pipe size(maybe 2" diamenter in order to weld it in place) and stock pipe size going out to a 2 1/4 inlet N1 type muff,...
Im going to muff shop this week to customize my exhaust and changing my N1 to a 3" inlet type,..Do you think I would be going overboard with a 3" vs 2 1/2 pipe from downpipe to the rear with my mods, and would this help my problem with the car not reving past 3100k easier? The guy is going to charge $120-140 for 2 1/2 size, so going to 3" diameter size a little more at $200 so not much diff,....Would the 3" be too overboard (lose torque or/and power)? Or is 2 1/2 good enough with a 3" inlet N1 muff going out the rear?
Any help needed quickly and very much appreciated,..
abakja1
abakja1
