need help with 60 trim install
CBgst
582
Jun 25, 2002
The turbo is in and everything is ready except the water lines. The factory water line from the oil cooler to the water neck doesn't fit behind the turbo. Can I just buy a long peice of rubber hose and route it a different way? What do I do with the water lines for the factory turbo? Can I just block them off or do they need to be looped? Thanks for the help!!!!
You can block the old water lines off. You can also reroute the line to the oil cooler with a flexible one and get rid of the hard line. I had the same exact problem.
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
