Race94
- 1,151
- Jan 6, 2003
Puerto Rico
Does this improve performance?
Do kits come w/pipes made that way or is it a custom thing?
The only problem is our engines are mounted differently. If we even could move the radiator back enough it would be heated by the exhaust manifold and turbo.
Check out their article. Maybe with some creativity we could do something similar but I don't think so. Their set up is on of the best short route systems I've seen. Later.Originally posted by 13secGST
your spool up is quicker because you have less piping to fill up with boost.
However with most FMIC kits such as mine the short routed piping is also 2.5" piping so it takes more volume and actually slows the spool time of the turbo even though the piping is short routed it has more volume due to the bigger diameter.
