super95awd
- 823
- 7
- Oct 11, 2002
Morgantown,
West Virginia
Ok, I leak tested and I had a huge leak at the j-pipe/comp housing and also one at the TB. Went and got some new gaskets, solved the leak at the j-pipe other than the fact that its now leaking out of a couple pinholes in the weld
. TB leak is still there. In third gear I'm probly not seeing full boost of 16 psi on my b16g until about 4500. Could boost leaks be causing ALL of this???
. Nah, the j-pipe is from Slowboy. I guess I'll go at it again tomorrow. I don't even hit full boost in 1st.
