Lordpaxin
- 1,890
- 15
- Apr 21, 2003
Jackson County,
West Virginia
Hello All,
engine is in, all 5 speed parts installed, and this is where i am at.
I need to put in the axles, the xcase, then plug everything in, jump the wire for the starter, and fill fluids up, and im done,
my guestion is, i was told i can use the oil cooler from the GVR4, the external radiator type, is this true,.
and, i have every other thing worked out, except the cyclone, i need a pin diagram for the jdm ecu, so i can direct wire it, thanks.
