TT won't work! Dang thing
Niknuk
59
Jul 2, 2002
Penn Hills, Pennsylvania
HKS type 1 TT, I spliced all the wires right, but I can't get the stupid thing to read rpms or speed. I'm gonna tear open my dash again when I get home to make sure I tapped the right wires. The first wire is the fourth one on the bottom from the right, the other wire is the seventh. Am I right on this? Both readings on the timer are 0. But everything from the harness and parking brake sensor work, just not the wires hooking up to the ECU. I have to have tapped the wrong wires. Dang I hate pulling that thing out.
Well, I figured out the problem. Those plastic jobs that HKS gives you with the timer are junk. Either that, or you have to use them right. :)
They weren't actually tapping the wire. So I took them off and tapped into the wire the old fashion way, cut and splice. Now the timer works perfect.
