random exhaust questions
sting0004
429
Oct 29, 2002
Buckscounty, Pennsylvania
I have a 2g awd. Can someone direct me to the cheapest mandrel bent downpipe that bolts to the cat? All the cheap ones i.e. exhaust depot and i think ebay downpipe eliminate the cat, i need a testpipe/cat for inspections. Is my best bet the trader or classifieds or does some vendor sell a cheap downpipe that bolts to the cat? Also, will a 2.5 in test pipe bolt to stock exhaust? A 3 in test pipe wont though right? A 2.5 in test pipe wont bolt to a 3 inch catback will it? Thanks for the help on my noobish questions, any help is appreciated.~Matt
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
    • jmt2028
